Old 09-11-2019, 09:26 PM   #5
Fiddlebog
Originally Posted by PorscheBear86 View Post
Hello I was wondering if anyone experienced the window on the passenger side not dropping from the exterior door handle after a new micro switch was installed? It works from inside but as soon as you let go of the handle the window rolls up and then hits the top door jam. It also makes a beep beep sound some times ?
This happened to my passenger door. turned out the connector to the latch (the 10-pin one) was making bad contact. Replaced the connector, fixed the problem.
I've never heard of anybody else having this solution, though.
Try wiggling that plug while the door is open. When I did this, it caused the window to go up and down and the horn to beep at me (this connector also tells the car whether that door is closed/locked), which is how I diagnosed the problem.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
