Originally Posted by Strawfordt
Well I guess I was being too gentle with the plug in. Forced it in and viola. Codes were there to be read.
So the codes I got are.
P 1130
P 1128
P 0446
The first two are Porsche specific. The third has something to do with emmissions I think.
Any and all help is appreciated.
Hi,
Here you go...
- P1130 - Oxygen sensing adaptation, idle range, Cyl. 4-6
P1128 - Oxygen sensing adaptation, idle range, Cyl. 1-3
P0446 - EVAP Cannister Shut-off Valve (function) - Sort to ground, blow lower limit, lean mixture threshold
I believe these still point to the MAF sensor. Could also be OČ Sensors given the mileage. Hope this helps...
Happy Motoring!... Jim'99
