Old 09-08-2019, 03:42 AM   #5
rfuerst911sc
In your original post you stated " Visual inspection shows no rattle or damage on CV axle joints " please explain exactly what you did or what this means . The axle universal joint mentioned above is the same thing as the CV axle joints . Usually but not always the first sign is the CV joint rubber bellows/covers are torn and throwing grease in the wheelwell or under the chassis . But a CV joint can be bad and still have good bellows . Classic symptom is a clicking or knocking noise as the axles rotate .
rfuerst911sc is online now   Reply With Quote
