Old 09-06-2019, 09:44 AM   #17
itsnotanova
Those brackets won't win a beauty contest, but I think they'll hold. If anything I would add another bolt or two to each vertical part. I also think you need to add another fan to the radiator. I'm running into cooling issues with my radiator set up. Your radiator is larger than the one I have but our fans look to be the same size. My car overheats if you try racing in over 90 degree day's. I just switched to an electric water pump but I'm not sure it helped.
Woody
