Old 09-05-2019, 07:52 PM   #204
AaronF
INFOSEC Ninja
AaronF's Avatar
Originally Posted by specboxCO View Post
I used a 40v A8 AUX engine in mine. Biggest decision between the 40v and 32v engine is whether to go drive by wire or cable throttle. There is a slight mod to the accelerator pedal wiring in the Boxster needed if you run DBW.
I'm at a point now where I've got my motor in the car and it idles beautifully, but no matter what I do I can't get the throttle pedal to work. I've studied many Porsche and Audi wiring diagrams and I'm almost positive that I've got it wired correctly now.
I'm using the ECU bin you provided in a previous post. I'm almost wondering if I didn't mess up the ECU when I first powered it on and the throttle pedal wasn't wired right.
Could you elaborate more on what your slight mod is? Thanks!!
'03 Boxster with an Audi S8 4.2L V8 - https://sites.google.com/view/boxsterv8swap/home
'06 Cayman S Tip
AaronF is offline   Reply With Quote
