Old 09-05-2019, 06:12 PM   #15
piper6909
piper6909's Avatar
Originally Posted by elgyqc View Post
I did the clutch on the Blue Boxster that I sold to a friend this spring, While the transmission was off I pulled the flywheel, then the IMSB flange (AFTER having locked the timing) and verified the IMSB. It turned smoothly and there was no play. I then pulled the seal off the bearing so that it would get direct oil lubrication. There was no grease in the bearing when I removed the seal. Put it all back together and it has been running fine since.
My logic and pictures here in post #60
sick of ims bearing
I've heard about pulling the seal off. I've also wondered about doing the European Parts Solutions procedure of punching a small hole on the other end of the IMS behind the oil pump so to send oil to the bearing. That is IF for some reason I need to remove my Tiptronic.
