Old 09-05-2019, 12:12 PM   #7
JayG
On the slippery slope
JayG's Avatar
Studs vs bolts .....
If you chamnge your wheels a lot, studa are the way to go. If you start trackingyourcar, you will likely change the wheel/tires a lot, sometines 2 or 3 times in a weekend. Studas save time and make it a lot easier to change the wheels.
If you don't change your wheels/tires often, stay with bolts, unless you are adding sopacers and don't want to spend the big$$ for the longer bolts, or the longer bolts may not be long enough with thick spacers
2004 996 Targa Tip
Instructor - San Diego region
