Old 09-05-2019, 12:10 PM   #1
redciv1
redciv1's Avatar
Angry Not 1 but 2 broken bolts on water pump!!!!
So I am removing my water pump after the bearing starts making noise. I take my 1st bolt off and fine. Move to the next bolt and 2 turns of the ratchet, I hear a noise on the ground. Head to the 11 position bolt breaks off. I move on to the other bolts and they are fine, I get to the bolt at the 1 position and the head snaps off as well. The first bolt left a little nub of the bolt but not enough to grab with vice grips. The second bolt broke flush with the metal. I already have loosened the front mount and dropped the motor as much as possible and bought some left hand drill bits. However, I am still having trouble getting to the bolts to drill out. Any suggestions as I even bought a HF right angle drill to access the right space? Helllllllp!!!!
redciv1 is offline   Reply With Quote
