How are the wheel bearings? You could be getting pad knock-off, which happens when the rotor can move around laterally, which pushes the pads back into the piston. It doesn’t take much to cause this, and even a little knock-off can cause a soft, or sometimes long pedal. And it’ll be inconsistent.
I had a race car with those symptoms, and it took me a while to figure it out.
