					Originally Posted by  NewArt
				I cut an 11mm box-end wrench in two to bleed the slave. Use a pressure bleeder and pass a long tube through the wrench to the bleeder nipple. Use an old 4 litre washer fluid bottle as a catch can.
Spot on NewArt. That's exactly how I've done in the past. I haven't received the new slave but I will report back when I finish the job. Thanks!
