Old 09-02-2019, 06:41 AM   #18
blue62
Originally Posted by Chi-Town View Post
I did buy it not running
Good idea on killing the pump, I'll try that in the morning
Due to the fact that you bought it non running I would do a compression test.
If it comes in ok that eliminates a lot of tail chasing.
If you have compression and your getting good clean fuel and spark into the cylinders you should get it to at least cough or sputter even if spark and valve time are a little off.
If you disable the fuel pump and use the starting fluid as above and have compression and spark you should get some sign of ignition.
