Old 09-01-2019, 01:30 PM   #12
The Radium King
The Radium King's Avatar
except, just talked w a person running a diasio w a subi engine and he had to stretch it 4" (which means revised bodywork, etc. etc. etc.) no no go. perhaps a saker?
https://vintageracecarsales.com/portfolio-view/2004-sakar-gt/
re no maf, you would have to go stand-alone ecu. run an alfa-n tune (goes off throttle position) and vacuum signal for idle (note that the obx unit has a vacuum plenum; would have to adapt a throttle position sensor to the cable throttle linkage) and presume go to wideband 02 sensors, as well as an iat sensor (since no more maf). all the new stand-alone ecus can drive variable valve timing these days.
