Old 08-31-2019, 10:15 AM   #10
Chi-Town
Ok, got up early before the heat started and did some basic diag.
Fuel pressure while cranking 34-36 psi
Showed spark on rear cylinder LH side
Pulled the plug, wet with fuel
Tried a squirt of starting fluid no change. (open or closed throttle)
No codes in any Modules
Cranks smooth, no noise
Does anyone have a video of an M96 cranking with a broken timing chain?
I'm thinking there would be a code stored if it broke even if it's only cranking?
I have a spare 2.7 but I was hoping to avoid the engine swap.
Chi-Town is offline   Reply With Quote
