Old 08-31-2019, 07:11 AM   #17
GLImages
Newbie
Originally Posted by Fiddlebog View Post
Funny you should say that. Same exact thing happened to me. I actually took the whole unit apart and used some QD cleaner on it.
But when I was having the issue, I would still get some sputtering, and sometimes it would start but run really rough. Had a few other weird symptoms before that as well. All cleared up with a good clean though!
Mine started with sputtering. Then just finally quit starting all together after a couple weeks of chasing my tail. What was throwing me off in my situation was the fuel pressure at the rail with car not running but key on was zero. New pump, regulator, cps, and still zero at the rail. Thankfully, I stumbled on the icv making noise. I swapped in a new one and had the normal 3.8 bar at the rail. I didn't think the ICV was THAT involved in fuel control. Its a simple 2 wire plug, so not sure what the ecu 'sees' from it. So to double check, I swapped the old ICV in and sure enough zero pressure at the rail again. [emoji2369]
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
