Old 08-30-2019, 07:53 AM   #16
Fiddlebog
Originally Posted by GLImages View Post
I went through something similar. It ended up being a bad idle control valve. The unit on the side of the throttle body. I played with the parts shotgun and replaced just about anything fuel spark related chasing a start, but no crank issue. (Cps, maf, plugs, fuel pump, fuel reg, 02 sens, etc). Finally just happened to hear a slight buzzing from the the throttle body when checking fuel pressure for the 10th time, gave the ICV a couple taps, buzzing stopped, car cranked and ran like normal. Like nothing had been wrong. I put a bosch unit in, no issues since. I had never heard or read of one failing, so I looked over it multiple times. Just throwing that out there.
Sent from my SM-G965U using Tapatalk
Funny you should say that. Same exact thing happened to me. I actually took the whole unit apart and used some QD cleaner on it.
But when I was having the issue, I would still get some sputtering, and sometimes it would start but run really rough. Had a few other weird symptoms before that as well. All cleared up with a good clean though!
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
