Old 08-30-2019, 07:51 AM   #11
blue62
Originally Posted by Fiddlebog View Post
blue62 is right.
Another way you can test spark is by pulling a plug out (make sure your fuel pump is disconnected) and grounding it out while cranking. Then you'll have a clear visual cue.
Fiddlebog,
Not a slam on you but that is a bad idea on a multi coil direct to sparkplug system.
use a spark tester made for the purpose. They are around 15 bucks I think. that way you eliminate any chance of mucking up the electrical system
