Old 08-29-2019, 11:12 AM   #1
djw8282
djw8282's Avatar
HELP Needed...Clutch Slave Cylinder or Pressure Plate?
Hello guys,
I've done some research on my issue but I thought I could get some help from those in the know.
Let me give a little history on the car. I had a new Sachs kit installed when I was having my engine rebuilt. The prior clutch kit before the new one installed was in the car for 10 years and was told the clutch had 50% left (so I think I know how to drive a manual). I decided to install a new one since I was getting an IMS upgrade. Fast forward 3 years and 35,000 miles later I'm having some issues.
First thing I notice a couple of months ago was there a squeaking/whirring sound coming form the slave cylinder area and brake fluid was down a tad bit from the MAX in the reservoir. I top it off but the sound did not go away but eventually increase in sound and the brake fluid level went down slightly again.
Next, maybe a week ago, I notice a little stiffness in getting into gear. Decided this weekend I would take a look underneath but did not make it. Car now will not go into gear when car is ON but will shift perfectly fine when car is off.
Last night I check the shift cables and everything was working ok. Is it possible that it could be the slave cylinder? Again, I did hear a loud sound coming from the area when I depress the clutch pedal. Or does it sound like a pressure plate issue? I thought I should change the slave cylinder before it has to be "opened up" to see whats going on. Please share your thoughts on the situation. Thanks!
Dan
djw8282 is offline   Reply With Quote
