1. Since you just replaced your battery, make sure connections are tight. Wiggle both cables to be sure.
2. If you don't have a meter or understand charging system, go to the Auto store of your choice and ask them to test your charging system (best) or battery.
The diagnostics aren't hard or expensive and is easy to isolate issue in most cases.
