Old 08-23-2019, 06:58 AM   #2
JFP in PA
Originally Posted by Seal1968 View Post
Do these values essentially tell you how far the chains have "stretched", or guides have worn causing a slight change in the factory parameters?
I use my VCDS for my Audi B 8.5 2.0 to monitor this very value, as they are known for a tensioner failure. Mine has the updated tensioner, however they only have so much adjustment available to offset chain stretch or guide wear before you need to replace the guides and chains. Audi calls it "adaptation" values.
I'm thinking this applies here too.
These cars have a deviation spec of +/- 6 degrees; values beyond that range indicate problems in the cam drive that need to be addressed.
