Thread: Pulley Numbers?
Old 08-22-2019, 05:43 AM   #8
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
You can check out the blog from Ben he provided in his video to see what bearing he ordered. The bearings should all be the same. He advised to pull out the bearings first to check for the part # so you don't order the wrong part. Geo is right that the bearing should be installed properly (flushed in right) otherwise you will run into issues.
1PorscheBoxster986 is offline   Reply With Quote
