Thread: LED Sill Plates
Old 08-20-2019, 01:29 PM   #6
Tweetdriver63
As promised, here are some pics from the EL wire install.
This first one shows what the EL wires looked like when they arrived. Just cut the cigarette lighter adapter off, but make sure you don't cut off the little black box!
Here's a link to those: (The ones I got were 1M in length, and they were just exactly enough, but with no room for error.)
https://www.ebay.com/itm/12V-Car-Interior-Light-LED-Glowing-Electroluminescent-EL-Wire-Automotive-Decor/254043718269?ssPageName=STRK%3AMEBIDX%3AIT&var=553390336246&_trksid=p2057872.m2749.l2649
This one shows the dimmer I got from ebay.
Here's link to that on ebay: https://www.ebay.com/itm/12V-In-Line-Dimmer-Brightness-controller-for-El-Wire-Panels-Tapes/153443318984?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I tapped into fuse A5 (instrument illumination) for power, and there's a screw just above and to the left of the fuse block for a good ground. You'll find it once you remove the trim around the fuse block.
Here's the wires running to the door.
With the door panel off, run the wires behind everything and pull the EL wire through the small opening at the rear of the armrest storage lid.
After the wire is pulled through that little hole, re-attach the door panel. The way the wires are designed, all you have to do is wedge the flat/tape part in between the panels. It will stay just fine.
Around the door pull handle, there's nothing to wedge the tape into. For this section, a small amount of trim adhesive will work, or you can use double-sided trim mounting tape too. I used the 3M 1/4 inch wide tape in this area. You also want to be sure you're mounting the EL wire where it will be visible. It will tend to want to hide behind the handle a bit here.
Once you have the tape in all the way around the handle, you're going to cut off the excess. (You can cut this stuff to any length and it still works.)
If you leave a little extra of the tape part (not the actual glowing wire part), you can fold it over to have a thick enough piece that it will stay put. If you don't do this, you'll have to use some kind of adhesive or it won't stay flush at the end (It will stick up exactly like it is in the picture above.).
That's it! I think they look awesome. If you do this, you'll definitely want to get the dimmer.
Sorry I didn't think to take pictures when I was installing the one around the instruments. For that one, take out the instrument cluster (but you don't have to unhook anything) and feed the EL wire up from underneath so that it comes out at the base of the binnacle on the passenger side. Wedge it in just like on the door handle. When you get to the bottom on the left side, locate where the end of the strip that you want to be able to see lit up is, then cover a few inches after that point with some black electrical tape if you don't want to have a glow from behind/under the instruments. (I didn't think of that, but it turns out I actually like the glow.) Then feed the EL wire down to the center console (where the stereo and other controls are) and down to where it will come out on the driver's side at the base of the shifter trim. I had to drill a hole in the plastic structure behind the A/C controls and storage shelf to feed the wire through (I covered a little of it with black tape there too, or it would have been visible between the sections of the dash face). If I had a longer EL wire, like the 2M length, drilling wouldn't have been necessary.
Tweetdriver63 is offline   Reply With Quote
