Old 08-20-2019, 07:53 AM   #17
JayG
On the slippery slope
JayG's Avatar
Studs shouldn't back out spontaneously regardless of loctite use or no, if the nuts are torqued properly. the only time studs without loctite should be able to "walk" out is during wheel-changing / nut-removal.
A properly torqued nut on a stud is at the same risk of coming-loose as a properly torqued bolt is.
Yup. They won't back out by theselves if they are tourqued.
In 3 years and countless wheel changes I have not had one loosen at all with blue locktite.
If you use red, and somhow break a stud, good luck getting it out. You may have to replace the hub
2004 996 Targa Tip
Instructor - San Diego region
