Old 08-19-2019, 06:30 PM   #22
dghii
Originally Posted by Allegro View Post
Lead acid batteries are not meant to go below about a 50% state of discharge. At least not often. And in cars that very seldom happens. But once? Your battery should be fine if you charge it fully, i.e. more than just running it in the car for a bit. Put in on a good charger for 24 hrs or more.
Its not that the batteries are not meant to go below 50%, its just that deep cycling LA batteries reduces lifespan.
IIRC, LA batteries will last for 5-7 thousand charge cycles when batteries are only slightly discharged (~80% charged). Same battery good for 5-7 HUNDRED cycles when discharged over 50%.
dghii is online now   Reply With Quote
