Thread: No down force
Old 08-15-2019, 07:01 PM   #19
Racer Boy
Racer Boy
Racer Boy's Avatar
I'd find an independent alignment shop, they'll do a better job anyway for less money. You can ask for recommendations here or locally.
The problem isn't your alignment, it's your shocks. Replace the shocks (and you may as well replace the lower control arms while you have it apart; in fact, you may as well also replace the sway bar links, inner tie rod ends, and trailing arms, because they aren't far behind the shocks in wearing out), and then have an alignment done . No need to waste your money on an alignment when it won't fix the issue, and you'll need another one after rebuilding the suspension.
