Old 08-15-2019, 02:22 PM   #2
Gilles
Do you smell fuel after cranking the engine? Check fuel pressure at the rail and maybe pull the fuel line to make sure that you're getting flow.
One time I had the same symptoms (with raw fuel smell), and turned out to be a loose harness connector, right behind the driver (thank you Brad Roberts for the tip..)
After removing the inspection cover it's on the lower side right against the firewall on the driver side, good luck!
