Old 08-13-2019, 05:26 PM   #2
blue62
Originally Posted by Jonconsean View Post
Hi,
I have a 2000 Boxster and I am having issues with the check Engine Light coming on. I am pulling the p1128 code and p1130 code. So have been reading forums and I have cleaned the MAF sensor and Throttle body and rest the codes. They come on after driving. Confirmed the Oil caps and gas caps are closed and the codes come back. I have replaced the MAF sensor and Oil filter , reset the codes and they still come on.
I took it to my Porsche repair guy and after a 10 min ($100) diagnostic , he said the MAF sensor is bad. I told I bought it new at Autozone. He said that it was either faulty or I didn't reset it right (which I think I did). He is charging me $400 for a new MAF sensor.
Does anyone have any advice/ suggestions. I am a little frustrated. Thanks for your help.
those codes refer to a short to battery positive on both of your post cat O2 sensors.
since it is both sensors with the same problem I would look for any fuse or relay that would affect O2 sensor function.
Then I would test the sensors
then look for a wiring issue
then look to a bad DME
