Old 08-13-2019, 06:47 AM   #1
Chi-Town
99' Base 5 speed Cranks / No start / No codes / New CPS
Ok the title gives you the basic run down
Duremetric has no codes in any modules
Engine cranks
Immobilizer has no water ingress or corrosion internally
Central locking works normally
30 amp fuse is good (all fuses pulled and inspected)
Fuel pump does not primer with key on or cranking
Fuel pump will run with relay bypassed (still no start)
New Genuine Bosch CPS just installed (no flutter on tach while cranking)
I'm stumped, I think I've read a few dozen threads about no starts but none like mine.
Any suggestions?
Chi-Town is offline   Reply With Quote
