Thread
Blue boxster resurrection project
08-12-2019, 09:11 PM
86
Homeoboxter
Homeoboxter's Garage
Boxster
At last I found some time to work a bit on the engine. As a replacement of the original dual row IMS bearing I decided to go with a roller bearing designed for higher speeds and higher radial load. For thrust control I`ve thrown in a simple ball bearing that I had machined to fit behind the roller. It`s a 2T scooter crankshaft bearing with C3 clearance to bear high temperatures.
Together they are just as wide as the original.
I had a groove machined on the outer ring to fit the original snap ring.
Homeoboxter
Find More Posts by Homeoboxter
