Old 08-12-2019, 12:48 PM   #2
JFP in PA
Originally Posted by bmsamson View Post
After 16 years I suppose anything can fail, but with the replacement part costing more than $150 i don't want to buy if that's not the problem. I recently replaced a bulb, and then had to pull the headlight unit again to work on the frunk release cable, then after have had several times when I turn on the lights and it takes a jiggle to get them going. If I hadn't been messing with the lights I'd think switch right away, but since I have, there's always the chance that it's just not connecting properly (though I've tried pulling and replacing it a couple of times just so see if that would clear the problem -- it didn't). Has anyone else had the switch fail? Know how to test it before I purchase a replacement?
Common failure. You can use the VW/Audi part as well, and it is cheaper. The Audi/VW part number is 4A0-905-849-B.
