Thread: '98/'99 boxster
Old 08-11-2019, 03:48 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
If not done recently, definitely water pump and tires. With the PPI have a check on AOS (crank case vacuum pressure with a manometer), window, door, and roof function, engine and transmission mount integrity, pulleys and drive belt. That's all stuff that will likely degrade with age regardless of miles.
Cost depends a lot on the shop. A good water pump is from $250 - $350 for the part. A recent forum post was talking about a shop charging over $1,000 for the total job. With a little experience it can be done in about an hour in the driveway with the rear wheels on ramps.
