Old 08-11-2019, 10:00 AM   #1
Gilles
IF (and that is a big IF) the cause is the AOS, then I would say that you need to stop running the engine. With that much oil flowing through the combustion chambers there is a good risk of hydrolocking the engine (oil is non-compressible) and causing permanent damage.
Perhaps be a good idea to remove all the spark plugs and crank the engine to remove the excess oil..
