08-09-2019, 07:11 AM
#19
Originally Posted by paulofto
I've done bleeding wet and dry and dry is by far the easiest and least messy. Do it correctly dry and you only have to refill the reservoir once. If you put fluid in the bleeder the after bleed clean up is more tedious than any other step in the process.
Exactly
"Cool Prius!" - Nobody
