Old 08-09-2019, 07:24 AM   #13
Fiddlebog
I usually install a resistor to drop the current drain and light output to about 3/4 or 80% brightness ( highest current drain ) and they will outlive most of us.
This is the correct way to do it. LED-circuits and incandescent-circuits are not directly interchangeable, as incandescent-circuits rely on the impedance of the bulb to operate nominally. An LED can be put into an incandescent-circuit in lieu of a standard bulb, but since LED impedance is so little, a drop-resistor is needed. Installing an LED without a drop-resistor will "work" but it will burn that sucker out quick!
Fiddlebog is offline   Reply With Quote
