Old 08-09-2019, 06:58 AM   #16
Starter986
1998 Boxster Silver/Red
I use my power bleeded dry, just for pressure.
As you need to keep adding fluid as you bleed, I put air fitings on the pressure line from the bleeder. That way you dont have to completely repump the bleeder when you refill fluid
OK. I may be lost...
"Add fluid as I bleed"? I'll be putting more than a cup of fluid into that bleeder. Isn't that counter-productive. Doesn't that bleeder hold like one gallon????? That isn't reconciling with my limited sensibilities.
If I use the power bleeder dry I:
Suction out some brake fluid from the reservoir...
Add brake fluid to the reservoir...
Screw cap onto brake reservoir...
Pump bleeder...
Bleed a line until reservoir level decreases...
Remove cap from reservoir...
Refill reservoir with brake fluid...
Reinstall cap to reservoir...
Be certain pump is at correct pressure...
Or:
Put brake fluid in bleeder...
Install cap to reservoir...
Pump to adequate pressure...
Start bleeding brakes until all are done...
Clean out bleeder...
Um... done.
What am I missing, seriously.
I find the alternative for which wholly the bleeder was designed to be incredibly inefficient.
If I'm missing something, tell me. I'll own it.
Thank you.
1998 Porsche Boxster
