Old 08-08-2019, 02:35 PM   #1
Alfa1712
Wow, that's a lot of calculating! Your prospective fronts are about stock. I would add a 10 or 15 mm spacer to push them out a bit. Don't go overboard as this could cause handling problems. You need 18 mm to bring your rears out to stock. Again add on 10 to 15 mm to push them out a bit, so roughly 30mm should do the trick for the rears.
Thanks NewArt.
I have read of some guys going with 23mm spacers at the rear, so in my case could I not go with 18mm to bring me out to stock + 23mm to fill the arch, giving a total spacer of 41mm at the rear?
Do I also need to consider the fact that my new set up is running 10" wide with 285 tyres, or is that irrelevant?..
Alfa1712 is offline   Reply With Quote
