Old 08-07-2019, 06:33 PM   #12
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by gti13 View Post
... How do you go about keeping this loose hose inserted in the hole?
Has the hole in the rubber sleeve that the vacuum hose goes into softened and stretched? Buy a new rubber sleeve: part no 99611068552 for about $25.
Or buy some tubing that is a little bit larger. I think the stock vacuum tubing has a 3.5 or 4 mm outer diameter.
Or just wrap a little piece of tape around the tubing to make it fit the hole more snug.
