Old 08-05-2019, 02:08 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
It looks like the wires are intact and the plastic connector is all that is broken. If at all possible, the best solution would be to de-pin the wires from the broken connector and insert them into the new one. I don't think that will work in this case though with the molded plug.
I'll take a look at one when I get a chance and see if it is fairly easy to release the wires from it. Otherwise, do a good crimp connection in the trunk. On the right side the wires enter the trunk from under the coolant tank, then lead to the harness.
