Right now I am looking to just find out if the DME should be putting 12v out on the cam sense pins (19 & 20) with the key on.
I know a bad DME can cause cam sensor, o2 & misfire issues. If someone knows for a fact that these pins should not be putting out 12v with the key on as I suspect or can check theirs when they have a moment that will verify that the issue is with the DME.
At the moment neither sensor is hooked up
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
