Thread: cam sensor
Old 08-03-2019, 07:03 AM   #2
JFP in PA
Thanks but the sensor you refer to as junk was installed in bank 2 not bank 1 which is where the code is referring to.
The question I have isn't about the sensor, it's about the voltage readings and if the issue is most likely the dme or wiring.
Have you scanned the engine and determined the actual cam positions yet? If you don’t know the actual cam allocations, it would be difficult to say if the issue is wiring related or a true mechanical issue.
