Old 08-01-2019, 08:46 AM   #1
Arete
Thanks for the info! I checked the light and it turns on when I turn the key (but not starting the car), so that doesn't seem to be the issue. I also checked the Clutch Pedal Cruise Control Cancel Switch, which seems to have failed (it was stuck in it's retracted position). I'll see if replacing that part fixes the issue.
Cheers
If you're cruise formally worked then quit, see if your cruise light bulb on the dash is out. If the bulb is bad, cruise will not work. Crazy but its true. Had the issue, tried the bulb switch (verified first bulb was indeed bad) and all worked again.
Arete is offline   Reply With Quote
