Old 07-30-2019, 10:18 PM   #10
Deserion
Multi-Boxer Driver
Deserion's Avatar
Originally Posted by Cunningr View Post
You have to buy a mirror assembly, they basically pop out but there are some wires inside so needs some soldering to be done right. Easily to take off the sun visor and work on a table. Remove 3 hex bolts but carefully.
Used visors from a later 987/997 work just fine to scavenge the mirrors from. No soldering is required to remove the mirror assembly and swap it into the Boxster's visors. Once the assembly is released (two tabs along the bottom edge, use a plastic trim tool to release) the mirror can be removed and then the contact bars can be removed. Same process to install.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
