If its the external hoses - probably not costly of you can do the work yourself. Replace parts and refill the system with coolant, which can be a pain.
If its the heater core, then it could be really expensive if you have to take out the dash to get to the core or its hoses. There may be a back door way to avoid disassembling the dash. Look for some threads where people to reseal re-foam the control flaps without removing the dash unit. These threads usually mention black pieces coming out the vents
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
