Most likely the voltage regulator, but you need to pull the alt either way. You can then have it bench tested. As mentioned, check your alt output. You could just have a bad battery as well, it happens. Pulling the alt isn’t the most fun job... it can be a real PITA in fact... plenty of info out there on how to do it.
