Have you tested the AOS by removing the engine oil cap while the car is warmed up and running? If the engine note changes and the engine wants to stall, then the AOS is bad. If not, then you're probably OK.
I used this method to determine that my AOS was shot, and I was able to replace it before it blew completely.
Just sayin;...........
TO
