Old 07-26-2019, 08:55 AM   #29
SCCA_AX
Normal autocross typically has a turn right off the start to attempt to minimize launch advantage. You also can start at your leisure, because you have to break the start beam to start the clock.
Pro Solo has an actual drag tree and at minimum 100' before the first turn. Timer starts when the light turns green, reaction counts.
Pro Solo is kinda like autocross on cocaine.
SCCA_AX is offline   Reply With Quote
