Old 07-25-2019, 10:45 AM   #2
particlewave
Should I understand that even if the/a fuse looks good... no burnt connecter... that it could be bad? If an electrical problem persists (similar to the OP), and the/a fuse looks good... replace it anyhow?
Any other signs to look for if the/a fuse "looks" good?
Thanks!
Absolutely. A fuse can be bad, but look completely normal. You can test it with an ohmmeter (anything over 1ohm is bad, good should measure under 0.5ohms), but they’re cheap and it’s easier to just swap it out. If swapping doesn’t solve your issue, the fuse was likely fine.
