Old 07-25-2019, 05:28 AM   #1
Starter986
1998 Boxster Silver/Red
Replace fuses A4 and A7 (for a layperson, visual inspection of a fuse tells you nothing about its condition).
If the issue persists, remove the headlight switch and clean the inner contacts (not the connector pins on the back) by spraying electrical contact cleaner into the switch and working the switch knob back and forth.
Should I understand that even if the/a fuse looks good... no burnt connecter... that it could be bad? If an electrical problem persists (similar to the OP), and the/a fuse looks good... replace it anyhow?
Any other signs to look for if the/a fuse "looks" good?
Thanks!
1998 Porsche Boxster
