Old 07-24-2019, 08:57 AM   #1
particlewave
Replace fuses A4 and A7 (for a layperson, visual inspection of a fuse tells you nothing about its condition).
If the issue persists, remove the headlight switch and clean the inner contacts (not the connector pins on the back) by spraying electrical contact cleaner into the switch and working the switch knob back and forth.
