Thread: surging at idle
Old 07-22-2019, 07:57 PM   #5
seningen
seningen's Avatar
Originally Posted by boxster_nut View Post
97 boxster with 33K miles. I recently changed the oil and filter. A day or two after this job, I notice the engine surging at idle - dropping down to about 300RPM then jumping up to maybe 1100 RPM, but it idles normally about 50% of the time. Sometimes it surges, sometimes it doesn't.
Turning on the A/C bumps the idle up to about 700 RPM and I haven't noticed any surging with the A/C on.
I checked the oil level and noticed that it is a little above the full mark.
I don't know if this is coincidence with another problem or related to the oil change.
Doing some searching about the surging and the most cited answer is to clean the TB and replace the Air Oil Seperator (AOS). I just don't want to throw parts at it, so how can I tell if the AOS is defective?
I will, however, remove and clean the TB as it has never been done.
Insight? Suggestions? Much appreciated.
J
Check your oil fill cap? Maybe its not on right, or its cross threaded.
Also to check your AOS -- you can undo the oil fill cap and see if there is a suction on the fill tube. If so, that's usually an indication of an AOS issue.
The other possibility is clean the MAF.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is online now   Reply With Quote
