Originally Posted by Box7774
... I found the door micro switch that supposedly functions as the window drop down via the door handle.........I am going to try this first before and window regulator work because it is easy and cheap....
Having found PelicanParts, you have probably seen the Tech Articles, but here's the link just in case:
https://www.pelicanparts.com/boxster/boxster_tech.htm
Most of it follows the 101 Projects Book, but being online there is a comments section and additional pics.
For the microswitch, I'd use a multimeter and test the switch in place before buying a replacement.
